- Announcing the TIB 2024 Advent Calendar (News:)
The Icon Bar: News and features: Visibility and pathfinding
Line of sight
6666666666666
6555555555556
6544444444456
6543333333456
6543222223456
6543211123456
654321@123456
6543211123456
6543222223456
6543333333456
6544444444456
6555555555556
6666666666666
Visibility, MK 2
Pathfinding
A*PerfectMediumHighLow
NoneLowFastNoneLow
Next time
