- Announcing the TIB 2024 Advent Calendar (News:)
The level generator
The current dungeon level.
Floor:XX £123456 Hungry Conf
#.....|.A..#B.|.....#
Room styles
Traps
Monsters and other items
  The level generator
  monkeyson2 (00:48 13/3/2007)
It's a map generator update!
batr2.png 320x250 736bytes
320x250
736bytes
batr4.png 320x256 1.2KB
320x256
1.2KB
No.
