Despite claiming to be a software Company, you may have noticed at recent RISC OS shows that they have also quietly diversified into hardware.
As this is a RISC OS review, the first thing we will focus is the choice to return to a blue theme. Personally I thought this argument had been settled long ago in favour of green (which is no longer even an option). ROD were not available for comment on the subject...
That aside, the cup works very well. There is only one capacity option but it seems a sensible default which most users will find acceptable. In practice, I found it worked well for drinking before it went cold. I tried a wide range of teas, coffees and other beverages and found no compatibility issues. It is very stable in use and I experienced no crashes or spills with it.
RISC OS Developments have produced the cups with the twin intent of raising awareness and cash and it seems to work well on both fronts.
ROD website
RISC OS Developments moves into hardware |
krisa (11:47 6/12/2019) Bucksboy (20:13 6/12/2019) markee174 (20:39 6/12/2019) flibble (16:24 7/12/2019) nytrex (21:26 7/12/2019)
Kris Adcock |
Message #124653, posted by krisa at 11:47, 6/12/2019 |
It's this kind of comprehensive review that keeps me visiting. |
George Greenfield |
Message #124654, posted by Bucksboy at 20:13, 6/12/2019, in reply to message #124653 |
Absolutely. This hardware clearly needs, and has received, a comprehensive ‘soak’ test. |
Mark Stephens |
Message #124655, posted by markee174 at 20:39, 6/12/2019, in reply to message #124654 |
Does all the work around here
And plenty of mug shots |
Peter Howkins |
Message #124656, posted by flibble at 16:24, 7/12/2019, in reply to message #124655 |
RISC OS breaks into the china market. |
Alan Robertson |
Message #124657, posted by nytrex at 21:26, 7/12/2019, in reply to message #124656 |
RISC OS breaks into the china market. Best of the one liners yet 11/10 |
